Ben Heck Featured Content
  • Ben Heck Featured Content
Forum pi 3 HELP
  • Subscribers 44 subscribers
  • Views 1145 views
  • Single Board Computer
pi 3 HELP
ramjit*8
ramjit*8 over 8 years ago
I would like to get some help, Please I assembled my Pi 3 it works but I would like to upgrade, By adding audio board, More RAM, Amplifier board, And a audio recording system. I am very new at this.
Any help will be greatly appreciated.
Regards
Bhim
  • mp2100
    mp2100 over 8 years ago +1
    Typically additional features such as audio is added with a raspberry Pi "HAT". One example is here: http://www.newark.com/pimoroni/pim138/phat-dac-for-40-pin-raspberry/dp/31AC5273?ost=pimoroni+DAC&cfm…
  • mp2100
    http://www.newark.com/pimoroni/pim138/phat-dac-for-40-pin-raspberry/dp/31AC5273?ost=pimoroni+DAC&cfm=true&ddkey=http%3Ae…
    A more advanced HAT from the same vendor is here:
    https://shop.pimoroni.com/products/pi-dac-pro
  • DaveMcLaughlin
    DaveMcLaughlin over 8 years ago
    Audio via a HAT as above but more RAM is not possible.
  • jomoenginer
    jomoenginer over 8 years ago
    RAM is hardwired on the board of the Pi so you really can't increase the amount of RAM on the PI; that is unless you are real handy with a soldering iron and know how to adjust the system for added mem. Not recommended.
    Some folks add or increase the Swap space, however this can cause the Flash or SD card to wear out quicker.
    The other option is to adjust the amount of memory used between the GPU and CPU:
    https://www.raspberrypi.org/documentation/configuration/config-txt/memory.md
  • ramjit*8
    Thanks to all who responded, I was overseas, Sorry for the late response.
    Regards
    Bhim
