element14's The Ben Heck Show
Forum Turn NES controller into a Vape mod.
  • Subscribers 30 subscribers
  • Views 1915 views
  • nes controller
  • nes
  • nintendo
  • vaping
  • retro
  • vape
bassslapme
bassslapme over 10 years ago
Hey guys, been lurking on the site for ages now, I watched the Ben Heck show around 2 years ago and decided to take the site a look see and boom I was hooked. Anyhow, I have quit smoking and have taken up vaping as its a less deadly habit. I have an idea to turn my Kangertech Subox mini into a NES controller mod which would look cool. I want the start and select to be taken off and i would use a rotary tool to grind down the plastic so the screen can go there showing me the wattage. I only have one problem, and that is making the A and/or B button fire it and the directional buttons (up and down) change the wattage. I have an idea of finding the tracks to the buttons and wiring the nes controller buttons to it but I would need to buy some buttons that work as the NES ones wouldnt (tact switches most likely would work). Only problem is it looks like it already has super tiny tact buttons soldered on. If i do de-solder the tact buttons, solder a wire to the connects and then solder the other end of the wire to the new buttons would their be any other problem?
  • kingrahl
    kingrahl over 10 years ago +1
    HERE is a complete right up on how to make your own. You can order custom controllers here.
  • kingrahl
  • bassslapme
    bassslapme over 10 years ago in reply to kingrahl
    There doesn't seem to be an actual write up on it there but it does list the parts which is mainly helpful with the type of wires to use and a source to buy them. Thanks man, this helped a lot.
  • ClarkD04
    ClarkD04 over 1 year ago
    Did you do it?
