element14's The Ben Heck Show
Forum Challege: Water cooled laptop
  • Subscribers 29 subscribers
  • Views 524 views
Hey Ben. I really enjoy my powerful laptop, but it really heats up. I was wondering if you could build a water cooled laptop that can run on just battery power? It would probably need a custom case and a very large battery (or 2). I saw what you did with your Xbox 360 laptop in regards to water cooling it, and thought something similar might work for a laptop. The only caveat would be making run on battery. I have seen other do it, but they always had it so the cooling system needed to be plugged in, which seem unlaptopy and more desktopy for me.
Also, I saw you making that swivel screen laptop, and was wondering if you could do it with a touchscreen laptop.
    I've done this mod before and truthfully its not worth it due to the amount of heat a laptop puts out and having the inlet and outlet lines subjected to all that heat constently it will never stay cooler then just having a fan.
    A watercooled laptop is inpracticle. A laptop is designed to be moved, a water cooled system is not. As any watercooler will tell you its not if your system will leak it is when and continually bumping and moving will increase the chances of it leaking.
