element14's The Ben Heck Show
Forum Project Idea:  PC Case with open window and on opposite side
  • Subscribers 30 subscribers
  • Views 588 views
All PC computer cases place components in the same side for years now..   example. if you are looking at the front of a Mid-Tower with a Windowed case its on the left side and all the parts go in from the left side...  well the left side faces my wall and therefore no one can see my Neon lights and cool parts showing.
I would like to see a case built with the WINDOW on the oposite side so when its sits on my desk the window is facing to the right and people can see the insides.
Here is a pictire of my Case with the Window on the left side...   again I would love to see one build with the oposite side
    This may sound dumb, but can't you find a box that can be turned upside down?
    are you looking to see the parts or are you looking to put a window in? They make hits that has the template and acrylic window and all the mounting hardware.
    If you want to see hardware, well some company might make a case like that but I never seen one. To make one you would have to cut out all the all the drive bays and move them to the other side and weld them in. Next you need to cut out the back panel and push the back in compleatly so the back panel will allow you to mount cards in a motherboard on the opposite side.
  • ZeroSizeObject
    ZeroSizeObject over 14 years ago
    Use a left side window panel on the right side. Just flip the door over.
    However, motherboards are meant, as a majority to be in a case with a left side door. Having a window on the right side would show the bottom of the motherboard, no?
    Z
    Buy on of this http://www.lian-li.com/v2/en/product/product06.php?pr_index=141&cl_index=1&sc_index=38&ss_index=96
