element14's The Ben Heck Show
Forum USB stepper motor controller
  • Subscribers 31 subscribers
  • Views 844 views
  • hardware
  • Controllers
  • ben_heck
jlcarender
jlcarender over 14 years ago
I am building a small cnc pcb router.  What would be the best usb stepper controller? to use with 3  4 wire stepper motors.
        Thanks Joe
  • Kelv
    Kelv over 14 years ago
    Hi joe,
    It depends really on how deep you wan to go, if are not afraid to open up an IDE and rattle up a software/hardware based PWM almost any USB enabled MCU could be used to do the job.
    One option to have a look at would be the application notes + developement kit from TI, DRV8824EVM unfortunaly this only details a Bi-phase system.
    Microchip also do a really good Dev board DM330022 with excellent application notes and exaple firmware already set up to prototype a motor controll application with devices capable of driving the stepper motors.
    The only other "problem" is the control side from the PC/Usb host. FTDI / Microchip and Ti provide easy to access windows drivers allowing you to generate the control application from a whole host of platforms.
    If you supply a little more info I will be happy to go into a little more depth.
    regards
    Kelv
    try http://www.phidgets.com/ . They have stepper motor control, easy to implement and pretty inexpensive.
  • jlcarender
    jlcarender over 14 years ago in reply to e14 Contributor
    Thanks xmetrix, I need a controller that will run 3 bipolar stepper motors the controller on Phidgets will only control 1. I am trying to do this as cheaply as possible.  I already have the motors and i want to eliminate the need for a microcontroller so i can cut down the cost.
    e14 Contributor over 14 years ago in reply to jlcarender
    They do have a 4 motor stepper controller but it's unipolar unfortunately. And I'm not sure if everyone would consider $72 cheap as I do lol. Oh well just a suggestion. Best of luck finding a solution,hopefully someone will chirp in with a link to something suitable.
  • jlcarender
    I agree $72 for the unipolar controller is cheap but 3x$72 for the bipolar controllers is not.  Thanks for the info i may need to try and find some cheap unipolar motors. I just think it is a waste of money to use a microcontroller when you already have a computer that can do the same job.
