element14's The Ben Heck Show
Forum If you had to pick just one.
  • Subscribers 31 subscribers
  • Views 539 views
QuantumAberrant
QuantumAberrant over 13 years ago
Hi Ben,
I've seen you use a CNC machine, a Lazer cutter and a 3D printer. I have limmited space and limmited funds and I'd like to know which I should you buy if I can only have one. I'm intrested in small projects centered around Arduinos, Raspberry PIs and older game consoles.
Collin
    I'm in the same boat.   I have a small apartment with limited space.  I decided to go with a CNC machine.  mainly because it is easier than the others.  I do hope to build a plastic printer next.  I also like the CNC because I could etch my PCB for other projects.  It would speed up my development.
    good luck
    I think it could come to what material you like best because both machines can cut different materials. But if you are worried about size the lazer cutter is a bit smaller and makes less noise but there is so much more you can do a cnc like @ashitakalax can etch pcb.
    It all comes down to if you want a smaller unit that makes less noise or do you want a bigger unit that can do more.
    ps: I have seen small cnc's but they can get expensive.
  • benheck
    benheck over 13 years ago
    I probably use my laser the most. It's fast, accurate and as easy to use a printer. Main negatives are cost and having to vent it.
    3d printing is awesome but slow, CNC is great for large stuff but makes a mess.
  • QuantumAberrant
    QuantumAberrant over 13 years ago in reply to benheck
    So if I can't vent the lazer then 3d is my best choice? I'll deal with it being slow. Whats a good starter 3D printer?
    Thanks image
  • benheck
    benheck over 13 years ago in reply to QuantumAberrant
    http://www.shapeoko.com/
