element14's The Ben Heck Show
Forum cheap DIY 3d printers
  • Replies 96 replies
  • Subscribers 40 subscribers
  • Views 8743 views
  • 3d_printing
what would be the absolute cheapest design to make a 3d printer?  could there be a build on this?
    e14 Contributor over 13 years ago in reply to biomedroy +2
    Dear Roy, I'm a mentor for a high school robotics team and as part of our off-season learning projects we are also building a MendelMax 1.5. Yesterday we got most of the electronics installed and ran a…
  • Vlee489
    Vlee489 over 13 years ago +1
    try http://www.solidoodle.com/
  • Nate1616
    Nate1616 over 13 years ago in reply to e14 Contributor +1
    Docdavies Having built numerous 3d printers over the years including the mendelmax 1.5 I would say you should look at a self leveling bed, upgrade your belts if your using t5/ t2.5 to something like the…
  • benheck
    benheck over 13 years ago in reply to e14 Contributor
    Remember 9/10 you're going to be printing SMALL THINGS.
    Don't get hung up on build platform size.
    shabaz over 13 years ago in reply to e14 Contributor
    It looks like they are not driving the far ends of each axis and one axis does not have a linear shaft on the far end (I could be wrong I just looked at the video on a low-res), which could save a lot of cost. I suppose it works because the size is a bit smaller, so for that size it seems it was a good design choice for them.
    e14 Contributor over 13 years ago in reply to benheck
    Yeah I know but I think there a bit overhyped because 300GBP for a reel of abs and I only printed a raspberry pi case
    Dear Roy,
      Yesterday we got most of the electronics installed and ran a test print in the "air".  We have not installed the print bed yet so we just moved the z zero up a few inches and let it run.  Worked fine, amazingly enough, but I shouldn't have been suprized, my kids are pretty smart.
      In anycase, we'd love to chat with you about your experiences (since as you, ours is widely sourced and home built) about your experiences.  It would be great to understand your print platform and which up-grades (since it seems 10 come out a day) you are pursueing.
      If you're interested, I can be reached at:
    docdavies2005@gmail.com
    Doc
    why dont u do a 2 in one cnc router and 3d printer to with a old psp hand held  with some usb card for the hard drive
  • Nate1616
    Docdavies
    Having built numerous 3d printers over the years including the mendelmax  1.5 I would say you should look at a self leveling bed, upgrade your belts if your using t5/ t2.5 to something like the gt2 belts or I've seen people use the  cable but then again your using a printed pulley which I personally don't like if your looking for better resolution.    Now if you have unlimited funds and looking the get the best printer then I would say well that's if your using the ramps board would be upgrade your steppers to at least the A4988 black edition or even larger drv8825.  I would also swap out you Wades or Greg extrudes for a none printed like the makergear geared stepper motors.  If you have any questions feel free to email me.
    Nate
    e14 Contributor over 13 years ago in reply to Nate1616
    Nate,
    Thanks.  My kit did come with gt2 belts and metal pulleys I do have the
    A4988 G3D stepper controllers.  I'll look into the Makerbot extruder...but
    $$ aren't once they  once were.
    And what is the self-leveling bed of which you are to be speaking........?
    Doc
  • Nate1616
    Hey Docdavies
    The G3D driver uses the Allegro 4988 which is what the Pololu uses.  The only difference is that the G3D has a 30k trimpot to help with the off timing of the motor.  Let me know what you think of it when you use the trimpot as I've never used it but might look into it depending on your review.  As for the bed leveling check out this link http://hackaday.com/2012/04/23/automated-bed-leveling-with-our-3d-printer/
    Nate
    Nate,
      Thanks, I'll look into it.
      Right now, since I'm just starting....I'm going to work on the spring,
    bolt, knurled nut system.
      We use the method you've mentioned to z zero our CNC machine.  The
    machine has the circuit built right in.
      I'll monitor the changes in Marlin....I'm still trying to make sure I
    just have MY settings right in that program.
      So much to do....but this stuff is cool.
    Doc
  • Nate1616
    Lol, I know how it is Docdavies.  If you have any questions feel free to send them my way.
    Nate
