element14's The Ben Heck Show
Forum cheap DIY 3d printers
  • Replies 96 replies
  • Subscribers 40 subscribers
  • Views 8746 views
  • 3d_printing
what would be the absolute cheapest design to make a 3d printer?  could there be a build on this?
    e14 Contributor over 13 years ago in reply to biomedroy +2
    Dear Roy, I'm a mentor for a high school robotics team and as part of our off-season learning projects we are also building a MendelMax 1.5. Yesterday we got most of the electronics installed and ran a…
  • Vlee489
    Vlee489 over 13 years ago +1
    try http://www.solidoodle.com/
  • Nate1616
    Nate1616 over 13 years ago in reply to e14 Contributor +1
    Docdavies Having built numerous 3d printers over the years including the mendelmax 1.5 I would say you should look at a self leveling bed, upgrade your belts if your using t5/ t2.5 to something like the…
    e14 Contributor over 13 years ago in reply to Nate1616
    Nate do you build your own 3d printers?
  • Nate1616
    Hey Daniel
    Yes I do build my own 3d printers.  I have built 5 so far.
    Nate
    Can I set you a challenge build a tiny tiny one that fiits on a desk ?
  • Nate1616
    Hey Daniel
    I would check out this link as most printers will fit on a desk without a problem.  http://www.reprap.org/wiki/RepRap_Options.
    Nate
    Imean stupid small
  • Nate1616
    Hey Daniel
    I suppose you could make it small but then what do you plan on printing with it.  Having a smaller printer means you have a smaller print area.  I always seem to run out of room with my current printers so going smaller would be questionable to me.  If you plan on printing really small objects I could see this but why limit yourself.  I would be more than happy to help you out if you would like to build one.
    Nate
    Smaller means cheaper and I'm on a budget of about 100GBP which means I should save but I only need to print about 5 cm high and 4 wide
    iam geting http://makibox.com/details/product/A6-LT and i want to mod to link it to a notebook and 3d scaner
  • Nate1616
    Hey Daniel
    To build a printer for 100GBP($153) is going to be hard to do.  The cheapest i have been able to build a printer for was around $300 and thats because i was able to print all the parts off another printer i owned.  The printer Billy posted is a little over your budget bud not far off.
    Nate
  • Nate1616
    Hey Billy
    When you say mod it what exactly do you mean?  To get it to work with a notebook all you do is plug it into the usb port same goes for the 3d scanner.
    Nate
