element14's The Ben Heck Show
Forum Show Idea: Build a device to smooth out 3d printed parts
  • Subscribers 33 subscribers
  • Views 843 views
  • episode
  • 3d_printing
  • idea
  • show_idea
I had recently read this article:
Slick Trick Adds Much-Needed Shine to 3-D Printed Parts
http://www.wired.com/design/2013/03/3d-print-smoothing/
It looked like something that might be of interest, since you've done several builds involving 3d printing.
The basic idea is:
ABS-based printed parts are placed in the jar with the acetone and heated to 90 degrees Celsius on the hot plate.
Acetone has a low evaporation point, but is heavier than air so the process creates a small cloud around the model which melts the surface,
slowly smoothing it to a mirror finish. After a couple hours, the parts solidify, can be removed, and be displayed with pride.
The results are actually quite striking. As I've been interested in getting into 3d printing,
its clearly something I'd be interested in seeing more on.
I'd be willing to bet others share this opinion.
Keep up the great work,
-Cam
  • Nate1616
    Nate1616 over 13 years ago
    Thanks for posting Cameron.  I've been into 3D printing for some time now and have never seen this process.  I will have to try it on my 3d prints and let you guys know how it works.
  • colecago
    colecago over 13 years ago in reply to Nate1616
    Ben has done the brush method of acetone smoothing.  I've mentioned vapor chambers as they've had a few hacks on hackaday with them recently.
  • benheck
    benheck over 13 years ago
    Sounds awesome, one of those things I would build if I had the time!
    So until then, brushes.
  • joecr
    joecr over 13 years ago in reply to benheck
    There was at least one kick starter project that made these for the backers.
  • Nate1616
    Nate1616 over 13 years ago in reply to joecr
    There was a kickstarter project using this method.  Here is the link http://www.kickstarter.com/projects/1809448130/3d-refiner-by-3dprintsexpresscom?ref=card
    Nate
  • krioux
    krioux over 11 years ago in reply to Nate1616
    I wonder if the phase of acetone changes something in the result.  Gaseous state is probably less aggressive and more dangerous, but with a finer result. If someone test both let us know!
