element14's The Ben Heck Show
Forum Challenge : Best 3D printer ever...
  • Subscribers 31 subscribers
  • Views 422 views
  • build_challenge
  • 3d_printing
  • viewer_challenge
  • challenge
  • ben_heck
Hi, i'm belgian and in belgium, we have the best quality of chocolate. So,why not use chocolat in a 3d printer?
Hadrien
PS: sorry if my english is bad...
    Actually this is something I have been thinking about myself as well, since you'd obviously have to have some sort of liquid feed mechanism - instead of the standard geardrive and heated emitter, I imagine you'd need a heated tank to keep the chocolate at an ideal level (adjusted and regulated differently per type of chocolate so that it wouldn't become too viscous) and then also maintain said temperature of the liquified chocolate until it reaches the nozzle, and also some way to control/regulate the flow and cutoff at the nozzle. I second this idea, actually. It would be awesome to be able to print 3D chocolate custom sculptures. (And could in fact be adapted over to other sorts of candy easily enough, you'd just have to stick with something that has a similar viscosity at a not-too-far separated temperature, or just use higher-tolerance nozzle/pipes/etc.)
  • Blacksheep32
    Blacksheep32 over 13 years ago in reply to e14 Contributor
    I think the chocolate is the hardest part of the project.  You need a chocolate that would cool quickly at room temperature, yet still be tasty.  Other than that, maybe a marble table?  I'm not a chocolatier, but this project sounds good!  I think I remember seeing someone making a frosting extruder, if I can find the link I'll post it up.
    Check out the fab@home 3d printer.  they have it printing with chocolate, cheese, and frosting.  not to mention with silicon and other 3d printing media.
  • benheck
    benheck over 13 years ago
    This has been done, many videos on YouTube if you do a "3D printer chocolate" search.
    Sounds yummy!
