element14's The Ben Heck Show
Forum Removing Hot Glue
  • Subscribers 29 subscribers
  • Views 305 views
  • hot_glue
  • ben_heck
  • ben
Removing Hot Glue
Hi Ben!
In the How to Not Fry Your Object video there is a scene of you prying/cutting apart hot glue.  There is a super easy way to remove hot glue from projects.  Use a q-tip dipped in 91% Isopropyl Alcohol and swab it around the glue where it meets the object to remove and where the glue will be removed from.  The glue should then easily peel off.
I have tried this on metal, plastic and even wood and it works a treat!  It should work on fabric as well, but I have never tried it.
Just thought I would put this here just incase you or anyone else who (like me) loves using hot glue in their projects.
  • benheck
    benheck over 13 years ago
    Cool, I shall try that. Thats!
    I use that alcohol all the time for everything else!
