element14's The Ben Heck Show
Forum New Idea for a show.
  • Subscribers 31 subscribers
  • Views 461 views
  • askbenheck
#AskBenHeck Hi Ben. I'm a big fan of your shows, I like the way you create things with almost anything. I was wondering if you have an idea for this.
I have a Dome 4.5" Pan/tilt/zoom Security Ip Network Camera 3x Optical Cmos Ir-cut System, model AJ-C0WA-C0D8
example (www.amazon.com/gp/product/B008414K7Q) that I was using as a security system in my house, but then I bought a CCTV security system and I'm wondering if the Wireless camera can be converted to work with the CCTV security system keeping the same pan/tilt/zoom functions. I was searching for information but I was able to find ways to use CCTV cameras as a wireless cameras using converters but not to work in the other way.
Thanks.
  • benheck
    benheck over 13 years ago
    Perhaps it could be remotely controlled over the web? Like a user-controlled Ustream?
    e14 Contributor over 13 years ago in reply to benheck
    Hi.
    Correct but the main feature I want or need is to record the video from that camera into the cctv system.
    Also, the camera has a function called Cruise, what it does is to start moving from left to right and viceversa until the function is deactivated, however this function only works when you are connected into the camera, once you end your internet session, the cruise stops automatically, this could be something that can be activated remotely and keep it working until we deactivate the function even though the internet session has been terminated and also the other feature, to record the video into the CCTV system.
    Thanks in advance.
  • colecago
    colecago over 13 years ago
    Throw a Raspberry Pi at it.  And by that, I mean use the Pi to bring up the cam(s) on screen and use the video output from the Pi as the input on one of the CCTV channels.  For controlling it, you can either use the web interface or use the Pi's IO to read some buttons/josticks, but then you have to somehow tie that IO into the web interface the cameras use.  I'm not a web programmer, but that part doesn't sound super easy to do.
