element14's The Ben Heck Show
Forum Viewer Challenge Idea: Monitor and laptop mods
  • Subscribers 31 subscribers
  • Views 526 views
Hello, Ben.
I have a laptop, and it's the only computer I have. I also have a bunch of perephrials I hook it up to when I'm home. They are: a 21" monitor, speakers, (a printer, a mouse, a keyboard, an external hdd and an optical drive) * connected throug a hub + LAN. Now, connecting all the stuff to my laptop takes some time, and the laptop itself occupies valuable space on my desktop. So I was wondering if it's possible to mod a monitor so that it could carry a laptop inside of it using some slot loading mechanism, like you've used in your nintendo mod. Turning on a laptop inside a monitor is a problem as well, maybe some wirieess solution? I've seen some guy used car anti-theft system to turn on his pc while he's on his way home. And to make things really awesome an external videocard can be hooked up, just need to make a miniPCI-e port on a laptop somehow...
The project is big an time consuming, so even a piece of advice will be appreciated.
  • colecago
    colecago over 13 years ago
    Why not just get a laptop dock?  Or make one?  And then the cables run from the dock to your peripherals.  A lot easier solution than basically putting a dock inside the monitor.
    e14 Contributor over 13 years ago in reply to colecago
    Unfortunately i don't posess the knowledge to develop a single connector interface to connect my laptop to perephrials... And I already have a solution that includes a hell lot of wiring, which I don't want to see.
  • joecr
    joecr over 13 years ago in reply to e14 Contributor
    What make and model of latop do you have? I ask because thier may be one already made for your laptop. You can try http://tinyurl.com/qhgmltt if you want.
    e14 Contributor over 13 years ago in reply to joecr
    It's Toshiba C850. It's a very budget model, so there is no dock port on it. The whole idea is to hide all the wiring from me so that I could just come home, plug a laptop into a monitor and press the button. Now I have to plug 6 wires or something, which pisses me off.
