element14's The Ben Heck Show
Forum Basic pocket computer display modification
  • Replies 32 replies
  • Subscribers 37 subscribers
  • Views 7467 views
  • pc
  • build
  • code
  • pocket
  • display
  • ben_heck
  • basic
ryan27968
ryan27968 over 13 years ago
Hi ben. I was watching old versions of your show and was wondering what is involved in changing the code for your basic pocket computer to work on a 20 by 4 display instead of a 16 by 4. I have tried messing around with the code but with no luck. Thanks in advance.
    e14 Contributor over 12 years ago in reply to e14 Contributor +1
    WARNING! I DO NOT HAVE ANY HARDWARE TO TEST THIS WITH! THIS MAY STILL BE BROKEN! tl;dr Now that that's out of the way, here's a (potentially) fixed copy of the script: https://gist.github.com/zanothis…
  • ryan27968
    is there no one who can help me here?
  • benheck
    benheck over 13 years ago in reply to ryan27968
    Did you use the original source code? That was meant for a 20x4 display.
    -Ben
  • ryan27968
    original? what do you mean?
  • benheck
    These files.
    1273.pocker_BASIC.zip
  • ryan27968
    ryan27968 over 13 years ago in reply to benheck
    this is the same code that i originally used, but it still does not work. this is written for a 16 by 4  not a 20 by 4.
  • rhyse302
    rhyse302 over 13 years ago in reply to ryan27968
    Did you use the 4 bit monitor?
  • ryan27968
    Yes. my setup is EXACTLY the same except its a 20X4 screen.
  • rhyse302
    It should work. It could be you need to use a special format or there is a flaw in the wiring.
  • benheck
    Ah, you probably need to re-arrange screen memory so it doesn't overflow the lines.
    Look through the code for instances of 16, or multiples thereof.
    e14 Contributor over 13 years ago in reply to benheck
    crossposted to a new thead
    I am too having problems getting my 20*4 screen (https://www.sparkfun.com/products/9568) working. I tried changing anything I could imagine having anything to do with the number of  columns in the lcdChar (), doFrame () and setup () routines. Do you know which lines exactly must be changed in order to get a clean output?
    thanks.
    ___________
    Edit (13.8.);
    I got it PARTLY working! THE 4 RIGHTMOST CHARS IN THE FIRST LINE ARE STILL MISSING AND DISPLAYED AT THE BEGINNING OF THE THIRD LINE. Anyone got help? For anyone who wants to know how, I changed the following lines in Tinybasic_2.ino (you find it here: http://www.element14.com/community/thread/25177?start=14&tstart=9)
    Line Nr.From (original code)To (modified code)
    23int screenMem[72];int screenMem[76];
    1481if (cursorX < 16) {if (cursorX < 20) {
    1489if (cursorX == 16 or c == 10) {if (cursorX == 20 or c == 10) {
    1491for (int xg = 0 ; xg < 16 ; xg++) {for (int xg = 0 ; xg < 20 ; xg++) {
    1494screenMem[40 + xg] = screenMem[20 + xg];screenMem[40 + xg] = screenMem[16 + xg];
    1495screenMem[16 + xg] = screenMem[56 + xg];screenMem[20 + xg] = screenMem[56 + xg];
    1503doFrame(56);doFrame(60);
    1535lcd.begin(16, 4);lcd.begin(20, 4);
    1537for (int xg = 0 ; xg < 72 ; xg++) {for (int xg = 0 ; xg < 76 ; xg++) {
    1543doFrame(56);doFrame(60);
