element14's The Ben Heck Show
Forum laser cutter that can cut at angles
  • Subscribers 31 subscribers
  • Views 1279 views
  • build_challenge
  • idea
  • viewer_challenge
  • ben_heck
  • show_idea
joecr
joecr over 13 years ago
How hard would it be to make a laser cutter that can cut other than just straight down? IE at a 45 degree angle or other angles as well. I don't even know where to start on that sort of project.
I was thinking either with mirrors or with servos moving the laser.
Please let me know about any problems you can think of, I didn't think about as I want to learn.
  • joecr
    joecr over 13 years ago in reply to Blacksheep32 +1
    I'd think wood, plastics that don't give off toxic fumes, & thin metal. I don't know if the metal part would be feasible as I'd think it might need a more powerful laser.
  • Blacksheep32
    Blacksheep32 over 13 years ago
    What material are you considering cutting?  As you move away from 90 degrees from the plane of the material the thickness of cut increases.
  • joecr
  • jds123
    jds123 over 13 years ago in reply to joecr
    you cannot create a very precise cut because of the way the laser works, however it is possible. You would have to find a way to move the laser, and write a program to move it in order to move the laser as it cuts. If you look at the picture the focal point is in one area but the whole hourglass shape is cut into the material, and as it is shifted it will cause issues with cutting. http://www.spikenzielabs.com/SpikenzieLabs/Laser_How_To_files/Picture%2017.png You're probably better off filing it down or using a router
