element14's The Ben Heck Show
Forum Air flow monitor
  • Subscribers 30 subscribers
  • Views 781 views
Air flow monitor
         I need to build a fan that can blow a fixed amount of air through a pipe, but hitting that amount can be problematic.
wondering if anyone can give me a hand on designing a simple circuit that has:
          electric fan (about 20mm pc fan, needs to pass upto 20 litres a second)
          veriable speed control (so i can slow it down as it get close to the correct volume)
          some way of monitring the flow (accurecy to 1 liter)
          some calibration ability
I was thinking of a simple pwm circuit with a counter to count the pulses and use that to tell how much air has passed
any help will be appreciated
Kind regards
K Rayton
  • sqkybeaver
    sqkybeaver over 13 years ago
    that is a huge undertaking, are you shooting for 1L/h or 1L/min accuracy? the later is a much harder to accomplish.
  • colecago
    colecago over 13 years ago
    Are you talking about counting pulses on the fan for the fan speed?
    There is a corellation between the speed of the fan and the air it can move, but I don't think you can just take the max rating they give at speed x and scale that when at speed y and be accurate, there are other factors in play and if you need accuracy you should use a secondary sensor.
    What are you trying to do with this?
