element14's The Ben Heck Show
Forum Need USB help
  • Subscribers 30 subscribers
  • Views 410 views
Need USB help
Blacksheep32
Blacksheep32 over 13 years ago
Hello all,
I'm trying to use a USB hub in combination with a NES to USB converter and memory card to make a Mini-Nintendo for my brother.  I hacked the power switch out of a broke nintendo and am trying to wire the switch with a LED into the 5v line in the USB, but when I test it I either get a good solid LED light or intermittent recognition of the HUB.  Any suggestions?
  • jds123
    jds123 over 13 years ago +1
    if the hub isnt powered it is probably drawing too much power, causing problems with the Pi. it doesnt put a high amperage signal to the usb because it doesnt get enough power to do so. it may also be…
  • jds123
    if the hub isnt powered it is probably drawing too much power, causing problems with the Pi. it doesnt put a high amperage signal to the usb because it doesnt get enough power to do so. it may also be caused by a bad power supply or a hub that isnt supported by the pi. heres a list of known good devices. http://elinux.org/RPi_VerifiedPeripherals
  • Blacksheep32
    Blacksheep32 over 13 years ago in reply to jds123
    This isn't a Pi based project, but your comment got me thinking about the power structure.  After meta-googling a bit I added a 1k resistor to the led and put that on a hub port (I originally had a 68ohm in series with the led and switch on the 5v power line),  I then added a a 10uF 25v cap between the power line and ground, and success!
    I will post pics when complete, and thanks for the inspiration!
  • Blacksheep32
    Blacksheep32 over 13 years ago in reply to Blacksheep32
    https://community.element14.com/resized-image/__size/300x300/__key/communityserver-discussions-components-files/75/contentimage_5F00_175791.html
