hi
i am going to build a portable raspberry pi and are getting the parts together and want to know:
- can i solder the li-po battery wires directly to the lcd and then from the same point run a wire to the power regulator and then to the raspbery pi or am i missing something (ground wires as well).
- should i power the raspberry pi through the gpio pins or is there a breack-out board i can buy to plug in-to the power socket and break out the pins as on the board they are very small.
thanks
