element14's The Ben Heck Show
Forum Build idea!
  • Subscribers 29 subscribers
  • Views 493 views
  • ben_heck_show
  • hide_and_seek
  • build_challenge
  • ben_heck
  • heck
  • ben
Build idea!
Hello, Ben!
I have a challenge for you to build.  Don't you sometimes want to play hide and seek, but you don't have a good (or any) opponent?  I think you should create a device that is able to drive around on the floor inside and avoid objects by using an ultrasonic (PING)))?) sensor.  It would also have a GPS onboard.  The player would have a small device with red and green LEDs (as well as another GPS module), and it would direct you with hot and cold until you are within a small radius of it.  When you find it, you tap the reset button on it and play again!
Thanks!
    Harrison,
    I love this - The kid in you is imagining...Fantastic!
    I looked further into this project, and I think that, if possible, hacking the Sphero would be a great way to do this!  It is programmable (by default), but some adjustments would probably needed to make it as Ben-Heck-ified as possible!
