element14's The Ben Heck Show
Forum Viewer challenge: Benchtop power supply from computer power supply.
  • Replies 7 replies
  • Subscribers 32 subscribers
  • Views 694 views
alamorobotics
alamorobotics over 13 years ago
How about a benchtop power supply from an old computer power supply.
I know that Ben did something similar with an old computer power supply in one the episodes, Episode 40: See Ben's Energy-saving Universal Wall Wart Episode.
I'm thinking more of a supply that besides the 3.3V, 5V, 12V fixed supplies and the USB charging uses a variable switching supply and a potentiometer to supply 0-12V.
A built in volt meter would be nice so you can see your variable output voltage, maybe a shunt to measure apmerage as well.
Maybe a fixed 9V supply for your favorite micro controller dev board or boosting the 12V to supply more than 12V on the variable output.
So take the "Universal Wall Wart" and upgrade it to a variable benchtop supply with volt meter and maybe even Amp meter...
  • colecago
    colecago over 13 years ago +1
    Sparkfun makes an atx breakout. I'd like to see a supply with some adjustable lines though https://www.sparkfun.com/products/9774
  • colecago
    EEVBlog had a good series on making your own adjustable power supply. I haven't watched it all myself, but they are usually pretty good and knowledgeable http://www.youtube.com/watch?v=CIGjActDeoM&list…
  • afmishaq
    afmishaq over 13 years ago
    This would be very useful. Many years ago, I used PC power supplies as a cheaper alternative to purpose built bench supplies for an electronics lab in a college. I just cut off the DC cables and terminated some wires into a connector strip for Ground, +5V, +12V and -12V. That is all that was required for simple digital and anlog electronics experiments.
    In the earlier version of power supplies you had to connect a small load to +5V to prevent it from shutting down. The later versions required a jumper to be installed in the MoBo connector.
    Faiz Ishaq
  • colecago
  • alamorobotics
    alamorobotics over 13 years ago in reply to colecago
    I got the breakout from Sparkfun and it's great...
    The reason I suggested the challenge is to see how to make an adjustable output with a volt meter.
    I got some switching power supplies and volt meters from E-bay and I'm going to try this myself.
    Still need a booster though so I can go above 12V on the adjustable output.
    So now it became a challenge for myself as well... image
  • colecago
    http://www.youtube.com/watch?v=CIGjActDeoM&list=PL7D15BC455533BCC4
  • alamorobotics
    Thanks...
    Those are some nice tutorials, I'm going to check them out tonight...
  • alamorobotics
    alamorobotics over 12 years ago in reply to alamorobotics
    Watched the whole series over the weekend, now I'm hooked on EEVBlog... ;-)
    Better Yet, Have Ben troubleshoot the one I screwed up.  It's now burned out or anything.  I just have not had time to work on it in a while, and I think he could probably point out common mistakes.
