element14's The Ben Heck Show
Forum Challenge: Equatorial Mount for Astrophotography (Computer Controlled?)
  • Replies 14 replies
  • Subscribers 33 subscribers
  • Views 1739 views
  • build_challenge
  • ben_heck
  • show_idea
Hey Ben,
I would love to see you take on the challenge of building a equatorial mount to help ametuer astrophotographers take long-exposure photographs of planets, stars and other deep-space objects such as Galaxy's and Nebulae.
For those who don't know what an 'equatorial mount' is, it is a motorized tripod-mount-thing to cancel the effect of the earths rotation during the exposure time of a DSLR camera with telephoto lens and/or telescope.
Adding computer control could further improve the design by assisting the focusing and positioning of stars etc.
I realize this is a step up from your time lapse trolley imagebut if a challenge like this what to be solved, it would benefit a lot of astrophotographers like myself.
Thanks a lot for your time. (And for making an awesome channel on electronic DIY projects)
Liam
EDIT: Picture and Caption Below, Few Grammatical and caption updates
Picture (Above): A Picture taken from a fixed tripod of the night sky. Exposure time:30 seconds. If you look closely, you will notice that the stars are slightly elongated; this is motion blur due to the earths rotation, having a equatorial mount wont only eliminate these spoils in the photographs, but will also allow for longer exposure times, and a deeper, clearer view into space. The two orange lights on the horizon are (from left to right), a city 30 minutes away and a town 10 minutes away.
    e14 Contributor over 12 years ago +1
    Assumption One: Understands the term "Declination",in re:Northern and Southern Hemispheres Assumption Two: Understands the difference between Right Ascension(R.A.) and Left Ascension(LA). Assumption Three…
    e14 Contributor over 12 years ago in reply to e14 Contributor +1
    Wow that's awesome! You'll never believe that I am 16 and building an equatorial mount then . If I (and Ben possibly) were to build a computer controlled mount, is there any other movements we could factor…
    e14 Contributor over 12 years ago in reply to benheck +1
    Cost is relative to the value of the equipment being used and whether this is to be a lifetime avocation or a teenager's whim. I have a portable;trailer-mounted observatory,that I built from my own plans…
    e14 Contributor over 12 years ago in reply to kas.lewis
    Wow this software looks great. I'll probably use it for my project. I read some where that you could control the mount remotely using this set up. You'd still need to write a program to control the motors, but including this would defineatly help (tracking, locating). I starting to think of a Raspberry Pi + Teensy 2.0 setup (of a teensy 2.0+++ if you needed more in/out pins)
    Liam
    So the second motor is to cancel out the fact that the earths rotation of offset from the orbital plane, so you need the second motor to track other planets.
    I am I correct?
    I look forward to seeing your blue prints. image
    Liam
  • colecago
    colecago over 12 years ago in reply to e14 Contributor
    Might not even need the teensy
    http://learn.adafruit.com/adafruits-raspberry-pi-lesson-10-stepper-motors/overview
    e14 Contributor over 12 years ago in reply to colecago
    Sweet anything to make it cheaper image
