element14's The Ben Heck Show
Forum 3d printers...how to?
  • Subscribers 32 subscribers
  • Views 640 views
fuzion_reaktor
fuzion_reaktor over 12 years ago
Hey Ben (or anyone else who reads this, I can't tell where this is being posted), love the show, but I have a question. Like you I have been bitten by the electronics bug and I am considering building my own 3d printer, preferably with stuff I have around to save money. I'me wondering if I can use a belt or two and guide bars with bearings or bushings to drive the x carriage up and down in the y axis. I've never seen a printer with a belt driving the y, and I'm curious if it can be done. I probably should get a kit since this would be my first 3d printer, but where's the fun in that? Also, any recommendations on cheap, easy and reliable control board? Thanks.
  • colecago
    colecago over 12 years ago
    I don't think it would be a problem if you get the mechanicals right.  I think many printers use belts on both, it definitely has the speed needed versus threaded rod.  My CNC machine uses belts on both x and y.  On Z they typically use a threaded rod style, I think for accuracy mostly.
    For control boards most people use RAMPS on top of an Arduino.  You can get knockoffs of those online pretty cheap, which I don't recommend (supporting community etc), or you can go with something like the printrboard which has everything on board, no need for separate drivers.
  • fuzion_reaktor
    fuzion_reaktor over 12 years ago in reply to colecago
    Ok, I think I may have gotten the arrangement of axis confused...maybe. I meant to drive the carriage up and down vertically. So if I were to do that I'd be using belts for all the axis. Also, thanks for the recommendation, I think I'll go with a printrboard, it sounds easier and less likely to blow up in my face.
  • colecago
    colecago over 12 years ago in reply to fuzion_reaktor
    Oh, yes, the Z axis is typically the screw axis.  I am not sure why they use screws on the Z, I imagine its for accuracy because that is more important than speed on that axis.  If you got a slower stepper, something like a .9 degree step versus the standard 1.8 that would help out a little, but I would probably stick with the tried and true ball screw.
  • Nate1616
    Nate1616 over 12 years ago
    You don't typically see a belt for the z-axis as you wont get the resolution that comes from the threaded rod.  It can be done but at a cost.  As far as the board, Colecago has a good point that Ramps 1.4 is a good all around board. I use these on most my printers.   If you want a newer version than go with RAMBO, which is just the Arduino and Ramps smashed together.  Just be aware that with the RAMBO if one thing goes bad it could be a little harder/more expensive to be fixed with everything all within one.
    Nate
  • fuzion_reaktor
    fuzion_reaktor over 12 years ago in reply to Nate1616
    Thanks. Out of curiosity, does anyone know where I can get all this stuff? I've looked in some stores and websites and everyone sells 1-10% of what I will need.
  • ckraft
    ckraft over 12 years ago in reply to colecago
    Generally the Z axis is a screw because it has more torque to lift the weight. With a belt you have to take steps to prevent the weight of the carriage from pulling itself down. With a screw you can use Acme threads which offer higher precision and accuracy.
    A belt will work on the Z axis, it is basically how a delta printer works. I don't see a reason to do it though beyond experimentation. It won't save any money and possibly create more issues.
