element14's The Ben Heck Show
Forum PWM
  • Replies 7 replies
  • Subscribers 31 subscribers
  • Views 780 views
PWM
royston02
royston02 over 12 years ago
Instead of a 50K pot can I use pwm signal to control it?
And in the loop write pwm*4 since pwm is 255 and analog is 1023?
    michaelkellett over 12 years ago
    To control what ?
  • Robert Peter Oakes
    Robert Peter Oakes over 12 years ago
    Use
    /* Map an analog value to 8 bits (0 to 255) */
    void setup() {}
    void loop()
       int val = analogRead(0);
       val = map(val, 0, 1023, 0, 255);
       analogWrite(9, val);
    right from arduino library Arduino - Map
    as far as replacing the POT control, it depends on wht it is connected to, you may need an RC filter to restore the PWM to an Analog Value
    As mark asked, what is this connected to
  • royston02
    royston02 over 12 years ago in reply to Robert Peter Oakes
    AN audio amplifier 50k pot volume control
    michaelkellett over 12 years ago in reply to royston02
    Are you asking how you might control the volume in an audio system by using the Arduino to operate the 50k pot ?
    If so there are two obvious solutions:
    use a motorised pot like this Buy Potentiometers Motorised carbon dual pot,50K log 27mm Alps RK27112MC01P online from RS for next day delivery.   (there are other sources on the web - Google)
    use a solid state pot like this AD5160BRJZ50-RL7 - ANALOG DEVICES - DIGITAL POT, 50KOHM, 256, SINGLE | Farnell UK
    If you could explain in a lot more detail what you are trying to do it would be easier to help.
  • royston02
    royston02 over 12 years ago in reply to michaelkellett
    trying to use pwm instead of a analog pot. The arduino will be connected instead of the three wires(i'am using only 2 G and S) and I will  have a infrared receiver and when I send an signal to the mcu,it will adjust the signal and since pwm is 255 and analog is 1023 if I type pwm*4
    in the loop will it work(I don't want my computer crashing)?
    I'm sorry but I don't understand - can you draw us a diagram ?
    Where is the pot in the system - what does it control ?
    if this is a standard audio amplifier your trying to modify then you will need to either motorize the current POT as described by Michael K above. or you could replace the POT with an equivalent digital POT and use the Arduino to control that .
    the reason your approach wont work on a standard amp is because the actual audio is passing through the POT and being reduced in size by a resistor divider network consisting of the length of the pot and where the slider is. so you cant simply replace it with a PWM signal to manage the volume.
    if it is not a standard amp then we would need far more details to be able to help. Make, Model of the amp, Pictures of the POT and its wireing etc.
    Regards
    Peter
