element14's The Ben Heck Show
Forum Filament extruder
  • Subscribers 31 subscribers
  • Views 712 views
Filament extruder
antoinec
antoinec over 12 years ago
How about a filament extruder that actually is combined with the extruder from the 3D printer.
You would load plastic pellets into the extruder at it melts and extrudes them directly on the heated bed,
basically skipping the entire filament spool part.
I hope you understand what I mean. image
  • colecago
    colecago over 12 years ago in reply to antoinec +1
    Not sure, think that type of design might work fine on a larger scale of pellet size to tube ratio, but I'd worry it won't be a consistent bead, which is really important. I've heard chips or marks in…
  • eliteeng
    eliteeng over 12 years ago
    The problem with that would be the hopper ( pellet container ) would need to be mounted on top of the extruder.
    You would need to upgrade your gantry to be able to handle all that weight. That's why they mount the spool on the back/side of the machine and just feed it in.
  • antoinec
    antoinec over 12 years ago in reply to eliteeng
    You could put the hopper on top of the 3D printer and guide the pellets in the extruder with a flexible tube that moves with the extruder.
    The other side of the tube would be connected to the bottom of the hopper
  • colecago
    I'd wonder how you'd get pressure in the nozzle. The extruder stepper bites into the filament pretty good and pushes it out. How do you do that continuously with pellets? Air pressure and some type of air lock system so you don't lose pressure as more pellets come in? Maybe pressurize the whole hopper system?
  • antoinec
    antoinec over 12 years ago in reply to colecago
    I would suggest a rotating screw conveyor inside a heated metal tube that pushes the pellets to the other end
    while they are being heated by multiple resistors. As the pellets melt, the tube and screw conveyor could get thinner creating extra pressure
    towards the other side. I guess the pressure is contained when the screw and tube fit closely together. What do you think?
  • colecago
    Not sure, think that type of design might work fine on a larger scale of pellet size to tube ratio, but I'd worry it won't be a consistent bead, which is really important. I've heard chips or marks in filament add air which is detrimental to 3d printing.
    I think it would have to be tested piece by piece, and projects with that level of uncertainty don't make the greatest episodes, especially weekly. Maybe a side project where he gives updates here and there.
  • antoinec
    Yes, that would be a nice side project indeed. If he finishes it as a compact and good working product,
    I believe this might be used a lot in the 3D printing community because it would definitely save us a lot of money.
    Although if Ben never makes it, I hope someone else does. image
