element14's The Ben Heck Show
Forum Facial Recognition
  • Replies 8 replies
  • Subscribers 31 subscribers
  • Views 813 views
  • build
  • idea
  • ben_heck
Facial Recognition
program4life
program4life over 12 years ago
Hello Ben,
     My idea is to have a facial recognition system that can remember faces and track faces.  I was trying to mount a camera to a mount that would allow it to have full range of motion.  I was hoping you could do it with an arduino.  The main idea though is to just have the camera look at a face, store it, follow it if it hasn't completely scanned it, then storing the information somewhere.  I look forward to hearing back from you on what you think.  Thank you so much!
Sincerely,
  • royston02
    royston02 over 12 years ago
    What purpose?
  • royston02
    royston02 over 12 years ago in reply to royston02
    depends on what purpose required
  • program4life
    program4life over 12 years ago in reply to royston02
    a system for monitoring who enters and area and then knowing who and when they leave.
  • royston02
    royston02 over 12 years ago in reply to program4life
    uisng a kinetic is 'quite' enough. Process information can be processed using MCU's(arduinoo is a nice example). Process info to computer(SD card will be too complicated). It can also record video+audio. Lots of books are written on these topics. 'IF' you don,t want such a complicated thing you can use any camcorder with audio or FPV cams.image
  • royston02
    also kinect can track faces easily.
  • colecago
    colecago over 12 years ago in reply to royston02
    The kinect processing I believe is done on the Xbox (at least the original kinect sensor), you aren't going to interface a kinect with an Arduino.
    I recommend looking into OpenCV or SimpleCV on a Raspberry Pi or Beaglebone Black for image tracking.
  • royston02
    royston02 over 12 years ago in reply to colecago
    Arduino and Kinect Projects - Arduino - Open Source
  • colecago
    • Interfacing Kinect and Arduino through Processing
    Processing usually refers to code running on your pc, which I'm pretty sure this is. I'm thinking it has a Kinect to a pc and then the pc to Arduino connection. I would really doubt the Arduino talks through the Kinect through usb which requires usb host mode, and has the processing power to decode the point cloud the Kinect sends.
