element14's The Ben Heck Show
Forum LED turn signal car light sequencer
  • Replies 19 replies
  • Subscribers 35 subscribers
  • Views 2899 views
What about an LED turn signal car light sequencer?
Very usefull and pretty Dawn Light style.
    e14 Contributor over 12 years ago +1
    I was Talking about something like this: www.youtube.com/watch
    mcb1 over 12 years ago in reply to e14 Contributor +1
    Rui The code to drive the neopixels is there in the post. The best way to learn is try yourself, you'll be amazed with how easy it can be by breaking it down into smaller chunks. Get hold of some neopixels…
  • splatten
    splatten over 8 years ago +1
    I've been working on a NeoPixel CANBus interface for a while now, I have various videos during development on YouTube: Brakes: www.youtube.com/watch Left Indicator: www.youtube.com/watch Right Indicator…
    Possibly.
    I was referring to the triple tailights found in some of the sixties cars.
    The original electro mechanical device is VERY expensive ... hence the replacement units using electronics.
    The Audi one just starts at 1 and sequences to xx than starts again.
    They obviously detect the flasher signal or they don't use the traditional flasher which is also possible.
    mark
    e14 Contributor over 12 years ago in reply to mcb1
    Audi uses since 2009, a digital blinker module on almost every model.
    So, no problems with the flashing cadence or load power consumption.
    There is also no problems with canbus errors.
    Here in Europe, this is street legal as long as the brightness is the same as a OEM lamp.
    I'll try to build a prototype. Instead of a regular SMD led, I want to use some Cree led, much more powerful in brightness.
    That's a benefit.
    You might be surprised how bright the Neopixels are running at 5v.
    There are the driver chips (WS2811) to allow you to use Super High brightness LEDs.
    IMO the Cree type would suit single lamp tailights, but not really suitable for the front indicator shown in the video.
    My car is an audi a3 sportback 2009. Non xenon. So no problem with space for the lights.
  • kingrahl
    kingrahl over 12 years ago in reply to e14 Contributor
    Rui Lima wrote:
    Can anyone help to create something like this.
    Here is a link to the wiring diagram and parts to the circuit I had previously mentioned. http://homemadecircuitsandschematics.blogspot.com/2011/12/how-to-make-car-led-chasing-tail-light.html
    If you wish to sequence more than 6 LEDs, you will either need to program a microcontroller or connect multiples of this circuit in a series.
    The title describes it as a taillight/ brake light circuit. In the description, it mentions the circuit may also be connected to the turn signals.
  • itsworthing
    itsworthing over 9 years ago
    Just working on mine now.
    https://www.dropbox.com/s/5yax30v1jhtqp9d/IMG_2193.MOV?dl=0
  • ronbo
    ronbo over 9 years ago in reply to itsworthing
    Looks nice... have you gone any farther with this?
    Have you considered adding some dwell time when the last LED is ON... before it restarts the sequencing loop?
    ...or possibly fade out: once the full string is lit, sequence OFF the string in like manner.
    The "ALL_OFF" at the end of each sequence just seems very 'abrupt'... when the sequence-ON seems so smooth.
    I assume the last demo was "emergency flashers"?
    What did you do for "Brakes" function... just "ALL_ON"?
    I'd be interested in seeing what you have, if you're willing to share.
  • ronbo
    I also meant to ask... how are you planning on driving these?  Are you going to tap into the "pre-blinker" wire that comes from the turn signal switch?
    ...or do you plan on running sequentials for the front turn signals as well?
  • splatten
    Brakes:
    Left Indicator:
    Right Indicator:
    Reverse:
    There are also variations of these with night lights on where the top and bottom row are lit red.  I'm now working on the CANbus interface to the car which should be completed very shortly.
    I am printing an enclosure for the strip to mount on the rear windscreen.
