element14's The Ben Heck Show
Forum LED turn signal car light sequencer
  • Replies 19 replies
  • Subscribers 35 subscribers
  • Views 2890 views
What about an LED turn signal car light sequencer?
Very usefull and pretty Dawn Light style.
    e14 Contributor over 12 years ago +1
    I was Talking about something like this: www.youtube.com/watch
    mcb1 over 12 years ago in reply to e14 Contributor +1
    Rui The code to drive the neopixels is there in the post. The best way to learn is try yourself, you'll be amazed with how easy it can be by breaking it down into smaller chunks. Get hold of some neopixels…
  • splatten
    splatten over 8 years ago +1
    I've been working on a NeoPixel CANBus interface for a while now, I have various videos during development on YouTube: Brakes: www.youtube.com/watch Left Indicator: www.youtube.com/watch Right Indicator…
    That would be pretty cool. Taking cues from the Mustangs on the road but making it look cool and not so slugish
  • kingrahl
    kingrahl over 12 years ago
    https://www.youtube.com/watch?v=SX01x1z7fTY
    Skip to about 24 min in. There is a circuit that he says can be used for turn signals using a 555 timer and a 4017 chip.
  • kidiccurus
    kidiccurus over 12 years ago
    Hmm... Not sure if this would be legal. Perhaps ask a police officer before you install it.
  • kingrahl
    kingrahl over 12 years ago in reply to kidiccurus
    I see them all the time around here. However, in my state you're not supposed to have a radar detector even though now they use DOPPLER. It wouldn't hurt to check your state and local laws. I feel like I've seen them standard in something like a Charger or Challenger or something.
    Woah that is awesome.image
    Sequencing tail lights were on offer for some vehicles back in 1966.
    I built one back in the 80's using a 555 and 4017.
    The latest one I helped repair fitted into the lamp socket, and had a chip on it that detected the number of pulses and turned the LEDs on based on that.
    Each one was designed to be in a certain position within the 3 tail lights, and at all times one or more lamps were on.
    They also fitted an electronic flasher since the LED tailights didn't present enough load to flash correctly.
    There are a few circuits around for them, but as Samuel has pointed out, they may not be legal, so check first.
    The ones on the Audi can be done using neopixels and there is some code here.
    Wireless Challenge .... the other bit -2
    Wireless Challenge .... Beer Tap (the other bit) - 4  Assembly
    Whether they end up legal may be the issue due to various laws regarding angles, brightness, etc.
    e14 Contributor over 12 years ago in reply to mcb1
    Can anyone help to create something like this.
    I have seen the circuit you are talking about I think thy call them knight rider circuits.
    Rui
    Get hold of some neopixels from a supplier that has documentation and support (that excludes some of the asian suppliers).
    Try their demos and examples to get it working, then try modifying them to do different things.
    This builds your knowledge of using them. (for instance mine wouldn't do what I wanted but I discovered I was starting at 1 instead of zero)
    Then progress until you build what you want, and configure it as you want.
    If you want these instantly, then I suggest buying the Audi in the video.
    Sorry I have too many other projects to build these.
    mark
