element14's The Ben Heck Show
Forum Portable to Console - Heck in reverse
  • Subscribers 29 subscribers
  • Views 230 views
  • idea
  • viewer_challenge
  • ben_heck
sirwmholder
sirwmholder over 12 years ago
Here is the idea.... I have a PSP fat 1001 with a broken screen and missing battery pack. As far as I know the unit works and can still play the UMD. I know I could just replace the screen but I find that lately I'd rather play games on the big screen instead of the 4.3 screen. I am unsure if the charging cable would be ok to run the unit for extended periods of time... or should a permanent power solution also be implemented? Also, I am curious how you would port out the current LCD connectors to either HDMI or Composite video... the older model is incompatible with the later released cable. Next, how would you go about removing the on board controls and setting it up to recognize a USB controller... preferably a wired X-Box 360 or PS 2/3 controller. Lastly, while modding is there a way to hook up a hard drive for increased storage capacity?
TL;DR: Strip a PSP fat model down... leaving the UMD intact to play games and movies... porting out the power supply, controls and audio/video... possibly adding a hard drive for storage.
  • kidiccurus
    kidiccurus over 12 years ago
    I don't know much about PSP so am unsure about video out. If you can by a cable, great, if not then don't bother trying. As for the controls, USB won't work. Why not just use the original controls and run power and av down a long cable. Using the charger for extending periods will ruin your battery, but that isn't a big problem. Lol.
