element14's The Ben Heck Show
Forum Can Crusher 2.0 Idea
  • Subscribers 31 subscribers
  • Views 546 views
  • ben_heck_show
  • ben-heck
michaelwylie
michaelwylie over 12 years ago
Ben;
I have two ideas, and they're more for the cool factor rather than practicality.
1. Use a solenoid with a plunger to catastrophically crush the can.
2. Use a vacuum system to suck the air from the can and watch it implode.
Mike
  • element14Dave
    element14Dave over 12 years ago
    Thanks Michael, I am putting together a blog for entries. Should be up soon!
    I was actually also thinking about a vacuum pomp. probably not the most efficient way but I think it would look cool to place the can on a platform with a hole and see it being crushed without any press. maybe you could make it that you press the can on the platform (since you probably need slightly more pressure to make it airtight enough) and this pressure will activate a button which activates a valve.
  • Kilohercas
    Kilohercas over 12 years ago
    Americans, so easy to impress.
    If you want to do it right, where is only two options:
    •     Very high current through inductor will create magnetic field, that will induce current inside can, and it will be crushed by it
    •     Very high frequency alternating current inside coil will induce very high current inside can, and due to resistance it will heat up and melt in seconds , and it will be possible to suspend mmelted aliuminium inside heater coil
  • michaelwylie
    michaelwylie over 12 years ago in reply to Kilohercas
    Canadian! image
