element14's The Ben Heck Show
Forum A cheap raspberry pi laptop
  • Subscribers 29 subscribers
  • Views 414 views
mechanicotardis
mechanicotardis over 12 years ago
Hi Ben! I have been watching your show for a while now and I have seen you make many things with the raspberry pi.
The idea I had was to make a raspberry pi laptop that a high school student could build.
Your criteria would be: have a keyboard and screen, have multiple USB ports for flashdrives and mice, and make the case by hand.
     Here's the trick though, you have to make it as cheap as possible, but still usable.
I would appreciate it if you where to make this.
Thank you!
                    Alex
  • royston02
    royston02 over 12 years ago
    Indeed, possible.
    A screen with composite would cost less. A normal keyboard that is used with tablets could work but make sure you can return it if it is not compatible with RPi. You could use a powered usb hub For hungry devices. If you want to make a case by hand, it is possible. But my advice is'you get everything ready a wanted and make sure you do all the mods. Then design a case in a designing software. Then post on the forum and we can help to decide what to put where. So it is better off this way. No problem if you take time. Just tell it though. Hope it helpsimage
