element14's The Ben Heck Show
Forum TrimPot Setup???
  • Subscribers 29 subscribers
  • Views 306 views
TrimPot Setup???
david98xp
david98xp over 11 years ago
I'm using a 100ohm trimpot. Is it un polarised? DO I need to use the middle pin?
  • supper_slash
    supper_slash over 11 years ago
    depends on what you are using it fore.
    if this is what your working with, than, from this view, you can use as an example.
    left post +5v
    right post GND.
    And middle/top post would bee your sweeping post, all the way left should give you +5v, all the way right should be 100ohm.
    let me know if this helps. but, if you must, the left and right posts are interchangeable, depending on how you wish the POT to work.
    I.E. if you placed +5v on the right post, and GND on the left, the sweep will be backwards. in this case turned all the way clockwise, this pot will give +5v, and counter clockwise, it will give 100ohm.
    If i missed something, please clarify or feel free to correct me guys.
