element14's The Ben Heck Show
Forum Raspberry Pi laptop/netbook?
  • Replies 16 replies
  • Subscribers 30 subscribers
  • Views 1899 views
  • help
  • pls
  • need
  • rpi
  • help!
  • laptop
  • heck
  • ben
  • i
Hi, I am wondering about what parts to use when making a RPi portable laptop, so as I can program, wherever I am.
the most important things are:
  1. Battery life, type and size.
  2. Battery voltage (needs to equal 5v, doesn't it?)
  3. The case
  4. it stays on when you charge it
  5. display size, (I was thinking 10.7 inch or below)
  6. ventilation
  7. an on/off button (will be used to turn on or off the 'RaspBook Pi' and to reset it, in the event that it freezes)
  8. keyboard (I prefer the mac- style keyboards, the keys are nicely spaced and are heaven to type on)
  9. touchpad (if possible)
  10. (in the event that a touch pad is unavailable for RPi) a trackball?
  11. speakers (I can't stand tinny sounding ones)
  12. that the RPi is left alone- no desoldering, I want to keep all the connectors on it, i want the Ethernet and HDMI out, but won't be using the composite, as nothing I own uses it, plus its broken on my B)
  13. SD card access
  14. the case should be universal with the B and B+ models.
  15. possible access to GPIO headers
  16. IT MUST NOT BE HANDHELD!
  17. a 'battery low' indicator light, maybe?
these are the main things that I think I need for this project!
I will need help with what materials to use, I may have access to a CNC machine, but i'm not too sure. I don't have access to a 3D printer either.
I will use a phone charger (probably iPhone or android, depends on what's easier to solder)
If you choose to help,
Thanks so very much!
Yours sincerely,
     Owen 'weeowey' D.
    I saw something similar to the battery pack you linked to me in my local supermarket, for £25, I can't remember how many mAh it has- I think it's 8000.. how long would that last?
    it had multiple USB's (I think)..
    ok, so now the display, I have no idea where to begin.. I want it to be above 7"in or maximum 10"in... i want something cheap, but I need the HDMI stuff...
    I can't find a cheap enough LCD, Help? it MUST be hdmi or DVI-D compatible, as they are basically the same.
    I found a LCD and controller-- http://www.ebay.co.uk/itm/RTD2660-Controller-Board-Kit-7-AT070TN94-LCD-Display-Four-wire-resistive-touch-/151327638606?pt=US_Monitor_Replacement_Parts&hash=item233bd4844e
    Will this do?
  • shanesissons
    shanesissons over 12 years ago in reply to e14 Contributor
    i would presume so a modern cell phone only has about 2500 and it can run all day so you could get maybe 5 or so hours out of it
  • shanesissons
    i found one thats the same also
    it looks like 7inch is about as big as you will get for a reasonable price
    http://www.amazon.co.uk/Tontec-Raspberry-Display-AT070TN90-Controller/dp/B00G60FJNG
    what if u use the powered hub to power everything as the pi and screen will be usb you could wire these to the inside of the hub
    how is your cad design i would advise designing the case before you build to get all parts to fit before you cut material
  • shanesissons
    here is a quick sketch based on a 7 inch screen i might plan on doing one of these in the future
    i have removed some of the sides for better viewing inside
