element14's The Ben Heck Show
Forum Custom Keypad for arduino
  • Subscribers 30 subscribers
  • Views 492 views
david98xp
david98xp over 11 years ago
Anyone know how I can build a keypad for my arduino project? lets say 8 buttons... maybe use i2c interfacing?
  • kidiccurus
    kidiccurus over 11 years ago
    If io is not an issue then I recommend you wire individual tact switches to their own pin and to ground. Then use inputPullup to have them pulled high by the internal resistors. They will read as high unless pressed in which case they will be low.
  • najath
    najath over 11 years ago
    If you don't want to use any external ICs, the best way to have more than 5 buttons would be to implement a matrix keypad. For this see:
    Arduino Playground - KeypadTutorial
    If you are fine in using an external IC, see:
    Arduino Playground - I2CPortExpanderAndKeypads
    For 5 buttons or less, the answer provided by kidiccurus would be the better option
