element14's The Ben Heck Show
Forum project idea: laser jet mod to directly print pcb to copper
  • Subscribers 30 subscribers
  • Views 526 views
  • viewer_challenge
ive just recently watched the pcb etching episode and thought why not mod a laser jet printer to print pcb etching straight to the copper instead of transferring with an iron. ive also had ideas on how to make multiple layered pcbs. using such printed cards you could print multiple cards on one sheet then using a cnc router to cut them to the exact shape consistently for mass produced projects or to layer them. with the printer you could even apply a decent solder mask over the printed cards after etching. id love some feed back from the community too
  • cncdan
    cncdan over 11 years ago
    if you paint them white first then print with black you just run the laser back and forward over then and it will only remove the white areas
    ive now watched  a few more episodes and seen ben's preferred method of paint and laser, but not having the luxury of a laser cutter, only a printer and the fact that it would make a logical mod since its a cnc machine in itself and feasible for us hobbyists just getting started. the translation to standard printer paper size and simplicity. the layered cards as well were mentioned by ben as i had thought of. also in conjunction with a cnc router you can make the exact shaped cards after printng like that in the minecraft block episodes instead of ordering them you could pop out 15 on a piece of paper sized pcb material. your only limited by the dpi off the printer to trace size.
