element14's The Ben Heck Show
Forum Regarding LCD Monitor Light Box
  • Subscribers 32 subscribers
  • Views 822 views
What would I have done ? I would have kept the LCD panel, combined with a RPI, and thereby have had an digital lightbox, where you could import pictures from USB to draw from.
    e14 Contributor over 11 years ago +3
    What would I have done ? I did this: Turn a broken laptop screen into a portable light table for drawing I explain in details how to do it, including how to reverse engineer the inverter pin out.
  • knight_rider1977
    knight_rider1977 over 11 years ago +2
    Adding to that idea with the RPI. Since 2 screen were used one could be just the light box and the other connected to RPI. This would give different options built into the same table. Then add a couple…
  • knight_rider1977
    Adding to that idea with the RPI.  Since 2 screen were used one could be just the light box and the other connected to RPI.  This would give different options built into the same table.  Then add a couple of speakers and the art desk is now a multimedia desk designed for the artist.
  • neilk
    neilk over 11 years ago in reply to e14 Contributor
    Hi victornpb that is awesome! I have a broken laptop.....now I have an idea of how to re-cycle it.
  • kidiccurus
    kidiccurus over 11 years ago
    Alas, hooking up a laptop LCD to a pi requires an expensive and often hard to find driver board. If you want to do something like that then I recommend just finding an appropriate standalone monitor and converting that. They don't always cost a lot, especially used. In fact, the one I am using to type this up was completely free from a local museum.
    e14 Contributor over 10 years ago in reply to kidiccurus
    Hi Samuel Doye, would you please be kind enough to provide details as to how you converted the standalone monitor to a computerized light box?
    I was researching the internet to see how to obtain/make one, but I am not educated in the field of electronics, so I will need help.
