element14's The Ben Heck Show
Forum No Color On Blue LED Light In PC's Power Button
  • Subscribers 30 subscribers
  • Views 815 views
  • problem
  • led
  • mouse
Hi Ben! I had great PC that worked fine but not for Minecraft. I saw my Power button that LED just stop lighting i think if  theres problem with it. I had old mouse that had LED light that had same color of my unlighting LED tell me what to do
A) Check connector
B) Take old USB Mouse's LED and connect
C) Recycle LED but not cable and test with USB's one
    First, not really what this forum is for.
    Second, does the computer turn on when the power button is pushed? If the computer turns on then its just a burned out bulb and no real reason to fix it since it would be more of a problem to fix.. If the computer does not turn om then the problem is not the bulb but a problem with the computer its self.
  • kidiccurus
    kidiccurus over 11 years ago
    If you need a step by step walkthrough to replace the LED, then you are probably not experienced enough to do so without damaging something. Either take the PC to someone who knows what they are doing or put up with a burnt out light. Your system will run fine without it and it is not worth the risk of causing damage.
    e14 Contributor over 11 years ago in reply to e14 Contributor
    but when i did turn off my pc using cmd it dint shutdown but i got my light working its beacuse it might be bios had little virus and it might be like that
    Bios virus, the system does not work at all, Corrupt any line in a the bios the motherboard will not turn on. Plus bios virus are extremely rare and need to be planted by someone sitting at the computer since they are so dangerous that they can destroy the system its made on.. A virus you get off the internet attacks the Operating system or data on the hard drive.
    Take the computer to a pro to fix.
