element14's The Ben Heck Show
Forum reflow oven
  • Subscribers 31 subscribers
  • Views 684 views
  • reflow
  • oven
reflow oven
i need help with code for a ardunio uno  for reflow oven please help thanks
  • clem57
    clem57 over 11 years ago +2
    Take a look at http://dangerousprototypes.com/2013/11/20/reflow-toaster-oven-using-an-arduino/ C
  • bobalexander
    bobalexander over 11 years ago +1
    What kind of help do you need? This project is ready to go: https://github.com/0xPIT/reflowOvenController
  • bobalexander
    bobalexander over 11 years ago in reply to e14 Contributor +1
    To setup your Arduino you will need to install the IDE (and possibly the drivers). Download them here: https://www.arduino.cc/en/Main/Software You should be able to use the built in LCD library to connect…
  • bobalexander
    0 bobalexander over 11 years ago
    0 e14 Contributor over 11 years ago in reply to bobalexander
    I Using 16,2 display blue with white 1602a display all i need is help with so it say preheat,soak reflow,cool down
    preheat     150 c
    120 c      120 to 0 then switch to next soak then so.... Hope this help i new at this . So i need directions on how to setup the ardunio uno my goal would be use the build my own board for the chip
  • bobalexander
    0 bobalexander over 11 years ago in reply to e14 Contributor
    You should be able to use the built in LCD library to connect to your 1602a LCD display.
    A good little overview and tutorial on getting this to work is here:
    https://www.youtube.com/watch?v=QRlVQWmIGgM
    If you have gotten as far as running a hello world program with the LCD your next step is creating a flowchart of the program you want to run with your oven.
    This helps to define the requirements and keep track of what you still need to do.
    I first define my inputs and my outputs, I then outline the program loop and the logic actions that are taken upon given inputs.
    Along those lines, is this purely a display or is it also controlling the oven?
    IT is to control a oven. I making solder reflow oven if this helps
  • clem57
    0 clem57 over 11 years ago
    C
