element14's The Ben Heck Show
Forum Uploading arduino code using bluetooth module "HC05"
  • Answers 2 answers
  • Subscribers 31 subscribers
  • Views 2122 views
  • bluetooth
  • fota
  • firmware over the air
dhiru
dhiru over 9 years ago
Hello everyone,
I am newbie to arduino and working on a project with arduino mega as heart of the project and a bluetooth module (HC05) that communicates wirelessly to the arduino.
I want to make an app that provide feature of uploading arduino code using "Firmware-Over-The-Air (FOTA)" using the bluetooth module.
Can someone help me from exactly from where to start?
  • clem57
    clem57 over 9 years ago +1 suggested
    https://docs.mbed.com/docs/ble-intros/en/latest/Advanced/FOTA/ gives a functional overview of what is needed.
  • clem57
    0 clem57 over 9 years ago
    0 dougw over 9 years ago
    Here is a video showing how.....
    https://www.youtube.com/watch?v=xXUKfTNHkKE
  • dhiru
    0 dhiru over 9 years ago
    Thanks dougw and clem57 for the quick reply.
    I came across some other links:
    https://www.youtube.com/watch?v=tccn3fy9qFU
    Corresponding android application source code: https://github.com/daisyworks/daisy-android-common
    Are there any changes required in arduino mega bootloader or will it work with standard bootloader of arduino mega?
    Further while pushing arduino code to Arduino from the android application, which commands which will be required to communicate between the android application and the arduino to upload .arduino code?
    http://ame2.asu.edu/staff/kidane/ArdWilessBtProg.pdf :
    This document mentions that the Wireless Programming can be done using three steps:
    1) Programming the BT module for 19200-baud communication.
    2) Adding a hardware reset circuit.
    3) Adding a reset function to your program.
    If same thing needs to be implemented in android application which commands will be shared between the arduino and android application before pushing the arduino code.
  • atrvicky
    0 atrvicky over 8 years ago in reply to dhiru
    Hey Dhiraj,
    Were you able to succeed with your attempt? Can you throw some light on it? Even I'm attempting a similar task. I need to burn code to Arduino Uno from an Android device via Bluetooth.
