element14's The Ben Heck Show
Forum Charging Voltages and Amperage for Wii U Gamepad
  • Subscribers 28 subscribers
  • Views 2286 views
  • wii u gamepad
zephenryus@gmail.com
zephenryus@gmail.com over 9 years ago
I'm looking at replacing my wall charger for my Wii U gamepad. It is rated 4.75V and 1.6A. Could I use this (http://amzn.to/2lwrLQH) with a 5V 2A usb wall adapter and not fry anything? Any advice is appreciated.
  • cstanton
    cstanton over 9 years ago +1 suggested
    Running anything out of specification is going to make it behave strangely. What will likely happen with this, is that the gamepad will get hotter, this will shorten its lifespan. It's likely that the…
  • cstanton
    0 cstanton over 9 years ago
    It's likely that the hardware is actually specified to approx 5volts, hence the specific 4.75 and it'll probably work. It's unlikely that your wall adapter, combined with the length of cable, will end up being exactly 5volts anyway.
    So it will work, for how long is unclear, you'd be better off ensuring that the voltage at the end of the cable is close to/at 4.75v using a multimeter.
    Basically you're running a risk of damage, it may be a low risk.
