element14's The Ben Heck Show
Forum Parts needed to build Hand Crank Phone Charger
  • Replies 13 replies
  • Answers 2 answers
  • Subscribers 29 subscribers
  • Views 1305 views
  • build
  • ben_heck
I'm interested in building the Hand Crank Phone Charger that Ben built in Epsiode 10. Ben mentioned that you need a hand crank charger (obviously), a Zener Diode, and a 10 Ohm resistor. This is my first real electronics build, so I'm not sure which resistor and zener diode I should purchase. Any suggestions/links would be greatly appreciated so that I can start this build.
    0 e14 Contributor over 15 years ago
    NTE5116A
    Is available at some Fry's.  as is the resistor. I could not see going mail order for just two parts. I also thought about adding a capacitor to level out the charger output, but then the circuit might not fit..
    well you have a list of the parts (other than a led wind up flashlight). I will ask if you have a multimeter, solder iron, solder, and either solder wick or a solder sucker? On a diffculty rating of 1 to 10 with 10 being the hardest, this is around 3 or maybe a low 4.
    So does this help?
    0 e14 Contributor over 15 years ago in reply to e14 Contributor
    Unfortunately, I do not have a Fry's anywhere remotely close to me. Would the following product from Digi-Key suffice?
    http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&itemSeq=96054808&uq=634323609112179398
    Also, I'm still struggling with which resistor I would need. Any thoughts on that matter? Thanks for all your help!
    I currently have all of those parts, with the exception of a multimeter, though I plan to pick one up before I start building this.
    the resitor is just a 10 ohm resitor, If you have a radio shack around, they would carry it. Just go in and tell them you need a 10 ohm resitor The multimetere, I baught a cheapy one from harbor freight for 3 dollars.
    Here is a color code of resistors. You will be looking for a band code of brown, black, black and either a silver or a gold band.
    They have the code and how to read the codes HERE!
    Pardon my ignorance, but does the wattage not matter? I see .5w, 1w, and various other variants.
    Would the following be alright: http://www.radioshack.com/product/index.jsp?productId=2062309&CAWELAID=107590978#inTheBox
    no wattage won't. To be safe you can use a 1w but its more expensive. The flashlight crank is making AC electricity which is in amps not watts. I used a 1/2 w 10 ohm but its what I had in my tool box.
    Fantastic! I now have a resistor and multimeter picked out (that $4 multimeter from harbot freight is a steal!), so I just have to find a place near me or one that'll ship the NTE5116ANTE5116A zener doide for cheap.
    Fry's will ship, but I am not sure how cost effective it would be.  There are a lot of items that use 5v, so getting more than one would not hurt. If you do not have a Fry's in your town, Ask a relative who does have one in their city to buy it and mail it to you would be the best bet.
    Would 1N5338BGOS-ND from digikey be alright? http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&itemSeq=96054808&uq=634325827450914251
    With shipping, I can get 4 from digikey for the price of one from frys.
