element14's The Ben Heck Show
Forum Challenge: hand held wii
  • Replies 9 replies
  • Subscribers 33 subscribers
  • Views 852 views
I've looked a lot on the new wii-u master controller (because i love nintendo) and i discovered that if you remove the optical drive of the original wii its about the same size so is it possible to make the wii hand held with or without the optical drive
  • colecago
    0 colecago over 14 years ago
    Having the Wii handheld wouldn't work real well with all the motion games, which is most of the Wii's library.
    0 e14 Contributor over 14 years ago in reply to colecago
    the motion control is in the wii remote itself so if you can find a way to put it in the console and make a substitute for the infrared detector it could work
  • colecago
    0 colecago over 14 years ago in reply to e14 Contributor
    It is in the Wiimote, but it requires a stationary target (the sensor strip).  So then you have to put a sensor bar up some where and run a cord, or do the opposite and have a stationary Wiimote and you are moving the sensors, making it not really a handheld.  I think the Wii Laptop is a better idea honestly.
    The "sensor bar" is not a sensor. It has infrared LEDs in it. The sensor is a camera in the Wiimote. That camera sees the positions of the IR LEDs and the console uses that video input to gauge the relative position of the Wiimote.
    What you see on the TV screen when calibrating the Wiimote is the Wiimote's camera view of the LEDs in the not-a-sensor bar.
    that is why you have to find a substitute for the infrared detector and if you are going to buy the new wii-u that wouldn't be a problem because you would have the infrared transmitter anyway
  • benheck
    0 benheck over 14 years ago
    They already have something hand-held with the same power as the Wii - any smartphone.
    Sorry but it's true.
    0 e14 Contributor over 14 years ago in reply to benheck
    you can say the same about the atari portable but you have made 2 of those. That is not the point off my challenge im just saying it could be cool to have a portable wii
  • Catwell
    0 Catwell over 14 years ago in reply to e14 Contributor
    Emil,
    It will be interesting to see how the wii-u handles portability. The IR sensor strip is built in to the front.
    If you attempt to create a portable wii, you might want to consider embedding the strip in the housing. However, unlike the wii-u, the original lacks all the various positioning sensors needed to operate like one device.
    Unless you are using the original wii as a portable console emulator, you will be limited in what you can accomplish in a hand-held design.
    Whatever you come up with, post it here.
    Good Luck.
    Cabe
  • kidiccurus
    0 kidiccurus over 12 years ago in reply to benheck
    Yes Ben, but can you play super Mario galaxy on a smartphone. I think a detachable, battery powered sensor bar would be fine.
