element14's The Ben Heck Show
Forum Portable Workbench
  • Subscribers 32 subscribers
  • Views 870 views
Portable Workbench
Looking for plans for the portable work bench. Any ideas?
  • colecago
    0 colecago over 13 years ago
    Check here
    http://benheck.com/downloads
  • Catwell
    0 Catwell over 13 years ago
    Go even more portable, no bench at all. Design everything virtually. See Multisim
    C
    I didn't find any dimensions. ut if you assume on revision 2 that the sheet it is cut from is a 4*8 sheet of ply. you could simply pull the image into a paint program and use the rulers to closely approximate the dimensions. remember that that if 4 feet on your screen is equal to 2 inches then divide 2 by 48 to get your scale in the case of 2 to 48 that is a 1:24 scale I.e. 1 inch equals 24 inches. Hope that this backdoor method helps you out.
  • benheck
    0 benheck over 13 years ago in reply to e14 Contributor
    It's in AI and PDF, if you load it into a vector art program all objects are actual size.
    -Ben
