element14's The Ben Heck Show
Forum Science fair idea!
  • Replies 7 replies
  • Answers 2 answers
  • Subscribers 30 subscribers
  • Views 788 views
  • build
  • build_challenge
Science fair idea!
Hi there! i am sophmore at Weslaco East High School (Weslaco Tx) and i am currently in the process of a Science Fair. Our school makes it mandatory for everyone in AP classes to participate in a Science Fair. (and it's worth 20% of the final grade soooo yeah i have to do it) My project last year was an Arduino controlled Drum machine (yes i am a drummer) . My partner and i used two solenoids driven by and arduino and a transistor circuit for the motion, and a MIDI drumset sketch written in Max 5 for the logic. Now, my partner graduated that same year and i have big plans for this project. My idea was i could use something more powerful yet very affordable (A RASPBERRY PI!! image) as a microcontroller with some sort of storage ( i was thinking an EEPROM) to save a pattern that could be input through a drumpad (some piezos maybe?)  I think this project could get me pretty far into the science fair, maybe even to the national level, but i felt it was better to consult with the community before i started.
Any help is appreciated!
-Lucas Cardenas
    e14 Contributor over 13 years ago +1 suggested
    Why would you need an EEPROM? I would think it would be easier to store the pattern in a file on the SD card that the operating system runs on. PS: The Raspberry PI has a microprocessor, not a microcontroller…
    PS: The Raspberry PI has a microprocessor, not a microcontroller. Microcontrollers are chips that contain RAM, processor, and storage space(programmable memory). The main chip on the Raspberry PI only contains a processor and RAM.
    well i was thinking of using a drumpad with piezo discs to record a pattern that you can physically play. i thought an EEPROM would help store that data cause of its quick read/write abilities, but i guess an 8gb SD card would work alot better. Thanks!
    The SD card can be kind of slow, you could just keep your pattern in RAM as a linked list, and give the user the ability to save the pattern on the SD card if they wanted to reload it later.
    Hi Lucas,
      Building a drum machine sounds interesting.  However, I'm wondering
    what is the science?  Typically, I think a science fair project involves
    an experiment to test a hypothesis regarding some scientific question.
    I'm not trying to be discouraging, just trying to help you think through
    how this is science rather than engineering.
    well yeah the 'Science Fair' is just the general name for it. It is divided into subcategories and last year this project fell under electrical engineering/computer science. do you have any suggestions?
    OK, I don't know the exact rules for your competition, but usually you
    want to do more than just build an artifact using known scientific principles.
    Instead, you want to actually discover or at least reinforce some scientific
    cause/effect relationship by doing some sort of experiment.  In the course of
    setting up the experiment you will often build an engineering artifact,
    but building something is a means to an end rather than the end itself.
    Maybe your scientific question could be "Is a RPi-based drum machine better
    than an Arduino-based drum machine for some specified purpose".  If your
    Arduino-based drum machine had certain limitations, you could do an
    experiment to see if an RPi-based drum machine would overcome them.
  • benheck
    0 benheck over 13 years ago
    Perhaps the 'science' could be a novel way of actually hitting the drums.
    So you control it normally, but how the drums are hit is unusual.
