element14's The Ben Heck Show
Forum Toothbrush battery loader
  • Subscribers 31 subscribers
  • Views 783 views
wasty
wasty over 13 years ago
Hi all,
I just wanted to ask a little question.
the electrical tootbrush of my wife had a broken battery. I unsoldered it and soldered a new one inside. But unfortunately i forgot to note the polarity of the battery.
The circuit inside is simple (See attachment (left is the coil ("powered" by an AC power outlet coil from the toothbrush holder), right the battery on top a diode).
I just wanted to ask if i soldered it right. I am only 99% sure but i wanted o ask for approval for the last percent :-)
Thanks in advance
Wasty
  • jds123
    0 jds123 over 13 years ago
    Because there is a diode (in the circuit you have posted) it will only draw current in the right direction. If it doesnt work reverse the polarity on the battery.
  • wasty
    0 wasty over 13 years ago in reply to jds123
    The motor works in both directions. It doesn't care how the battery is polarized (i tried it), The motor is parallel to the battery.
    I am not concerned about function but about battery loading.
    Coming from the diode only the positive half-waves of the AC voltage will pass through. If i inserted the battery the wrong way the battery will be loaded wrong (and probably will becom defect (in the best case)). Or am i wrong?
    looks right to me.
    youve got it so the magic smoke is poured into the battery. If you put it the other way, the smoke might come out and there would be none  left to power the toothbrush.
  • jds123
    0 jds123 over 13 years ago in reply to wasty
    It should work perfectly fine, on second look I realized you were looking at the charging not the actual function of the toothbrush. The diode should let current through and then the ground is connected to ground, but just to make sure test it with a multimeter. Make sure the  + is hooked up to the + output and ground is to ground just to be safe.
  • phoenixcomm
    0 phoenixcomm over 13 years ago in reply to e14 Contributor
    LOL the magic smoke answer!!!
  • phoenixcomm
    I looked at the print and the answers..
    Ok use it until the battery is not charged..
    Then see if the brush takes a charge.
    Yes ::= All is well.. Do nothing.. have a beer.
    No ::=  OK all this means you have to turn your battery around. Do that and then have the beer.
    image enjoy
    Cris
