element14's The Ben Heck Show
Forum large 3d printer
  • Replies 7 replies
  • Subscribers 33 subscribers
  • Views 811 views
  • build_challenge
  • 3d_printing
  • viewer_challenge
  • challenge
large 3d printer
joecr
joecr over 13 years ago
Can you make a printer that has a 1 cubic foot printing area? I don't know if there are hot plate that large or what other challenges it will run into.
Also could it one up the 3-way Quick-fit Extruder and Colour Blending Nozzle with 5 filaments instead of just 3.
  • benheck
    0 benheck over 13 years ago
    8" x 8" (or 200mm squared) is a very common size already, with many existing parts to choose from.
    Very rarely would you need to print something a cubic foot (and also it would take forever)
  • joecr
    0 joecr over 13 years ago in reply to benheck
    What about the "Also could it one up the 3-way Quick-fit Extruder and Colour Blending Nozzle with 5 filaments instead of just 3."?
  • benheck
    0 benheck over 13 years ago in reply to joecr
    Looks like that guy already did it. I'm sure 3 colors is hard enough. 5 is overkill.
  • ckraft
    0 ckraft over 13 years ago
    The biggest 3D printer i've seen, that was still functional anyway, is this one http://www.grassrootsengineering.com/blog/2011/09/08/the-big-3d-print/. It is an impressive job he did building it.
    I would note something from his page, his example print took two days to complete.
    This is something people do not consider. The bigger the printer, the bigger the print, the longer it takes to complete. The longer you print the more the probability that something will go wrong and screw up the print.
    That is why it is worthwhile to break prints down into smaller components if you can.
  • Catwell
    0 Catwell over 13 years ago
    Joecr,
    The Objet1000 is currently the world's largest 3D printer.
    See more here...
    C
  • Nate1616
    0 Nate1616 over 13 years ago in reply to Catwell
    There is a company called Re3D that makes a printer that has a print area of 24"x24"x24".  Here is the link http://re3d.org/.
  • benheck
    Chris brings up a good point.
    Also the larger the build, the higher chance of errors, and the more time you waste if the part "messes up".
