element14's The Ben Heck Show
Forum Thumstick/ Analog stick board
  • Replies 7 replies
  • Answers 2 answers
  • Subscribers 32 subscribers
  • Views 803 views
  • ben_hack
Dear Ben,
In one of your episodes you controlled a cnc router with a device which looked like a homemade boerd with two xbox 360 analog sticks. i was wondering if you would share how to do this as it would be a great addition to one of my projects.
Thanks a million,
Devin
  • ckraft
    0 ckraft over 13 years ago
    It wasn't that complicated really. The motors on that CNC machine were driven by dedicated stepper drivers. Those drivers have pins for direction and steps. So the analog input of the sticks was fed into an Arduino which just read the analog range to tell if they were left/right, up/down. Then based on that information it triggered the right logic for direction on the particular stepper driver X vs Y.
    It really comes down to the motor drivers. If you have motor drivers that allow you to specify direction easily then the rest is easy. I may still have the code around here somewhere if you would like to set it up yourself. If you don't have motor drivers that allow for easy control though its not going to work.
    0 e14 Contributor over 13 years ago in reply to ckraft
    Thanks for the detailed respose! I was actaully looking to mounting two joy sticks to a board but i was unsure the pinouts and the code used to decode this on the ardrino.
    Any help would be greatly appricated!
    Thanks again Chris
  • colecago
    0 colecago over 13 years ago in reply to e14 Contributor
    They are pretty simple, they consist of 2 potentiometers and sometimes a switch.  You apply voltage across the potentiometers, then put the wiper of the potentiometer to the analog input on an arduino, and that's about it
    http://www.adafruit.com/products/245#Description
    0 e14 Contributor over 13 years ago in reply to colecago
    so Im an newbie at this is there any way i got see a fruff sketch up or image?
    Thanks again
  • colecago
    https://www.sparkfun.com/tutorials/272
    thanks!
  • benheck
    0 benheck over 13 years ago
    99% of the complexity with CNC is in the software that generates tool paths. Same with 3D printers.
