element14's The Ben Heck Show
Forum Gamecube dvd Hack
  • Replies 8 replies
  • Subscribers 33 subscribers
  • Views 782 views
Gamecube dvd Hack
gnolan97
gnolan97 over 13 years ago
I'm trying to mod a gamecube using Raspberry Pi and mame software. is there any way to hook up the mini DVD play to the Pi. I plane on using this as a portable player with a 5" screen and a battery.
  • Nate1616
    0 Nate1616 over 13 years ago
    You can get an external DVD drive and take it apart.  But with an external dvd drive you would need and external power source as the usb on the pi wouldn't have enough juice to power it.
    Nate
  • benheck
    0 benheck over 13 years ago
    Why do you want a DVD player in there?
    A $10 SD holds more than that nowadays.
  • gnolan97
    0 gnolan97 over 13 years ago in reply to benheck
    I know the card or usb drive will work but I was just woundering if I could use the same mini dvd drive since it was already there.
  • Nate1616
    0 Nate1616 over 13 years ago in reply to gnolan97
    What are you trying to do with the dvd drive?  As the gamecube drive does not allow you to play movies you could however take apart another dvd drive and swap out the parts.
    Nate
  • fidelsalinas
    0 fidelsalinas over 13 years ago
    You could use a USB DVD drive if you really wanna, but good luck with the drivers.
    F.S
  • TCPMeta
    0 TCPMeta over 13 years ago
    You can use openelec for DVD playback. I would use a slot load based laptop DVD drive. Then I would modify a laptop charger as my power source to power the DVD, Pi and LCD.
  • benheck
    Is there even a way to read using the mini DVD player?
    -Ben
  • gnolan97
    I figured if I could get it wired up it would be the same as oa regular DVD so I could use openelec. My other ideal was to put a small lcd screen on the cover so you could pop it up and strip all the mini dvd components out. Since it was there I just wanted to try to use it.
