element14's The Ben Heck Show
Forum need flat flex cable 60 pin .5mm pitch 500mm long
  • Replies 9 replies
  • Subscribers 30 subscribers
  • Views 1116 views
  • mod
  • ps3
I need this to complete my ps3 mod. I have looked on the net for days. Can anyone help please?
  • colecago
    0 colecago over 13 years ago
    Something like this?  Or do you need it longer than stock?
    http://www.ebay.com/itm/Sony-PS3-Motherboard-410A-Blu-Ray-Drive-Flex-Ribbon-Cable-Models-CECHL01-CECHP01-/280968990109
    410A Blu Ray Drive Flex Ribbon Cable
    0 e14 Contributor over 13 years ago in reply to colecago
    I need it longer then stock. The stock cable is 250mm. But i need twice as long at least.
  • colecago
    0 colecago over 13 years ago in reply to e14 Contributor
    Oh wow, I didn't even read the full title, yeah it says 500mm lol.
  • colecago
    Someone on a forum said they used 80 pin and just cut away the pins they didn't use.  I'll see if I can find any 80 pin cable, it seems things kind of dry up after 50.
    Yeah i noticed Lol. I had an idea to get a bread board and make a sort of jumper extender with two conecters and an extra stock cable. But I'm afraid. That it may cause a delay. that's also assuming I could find the parts needed.
  • colecago
    If someone had a board like this in 60 pin you could probably solder some FPC connectors on and use two cables
    http://www.newark.com/roth-elektronik/re900-02/adaptor-smd-0-5mm-28-48pin/dp/59M1629?Ntt=RE900-02+-+ADAPTOR
    Or you could make your own interface board, would take longer though.
    I will have to roll that idea around for a bit. Time is not an issue, but on the other hand my skill level is something to make me not rush into anything image
    Hi, I advise you to find it on this website:Flexible flat cables, flexible printed circuit,FFC Cables/FPC cables manufacturer, enclosures manufacturer., this company can offer custom FFC Cables.
    Darlox is mainly engaged in the design and manufacture of custom cables for flat-panel displays and the peripherals; custom cables for auto, mobile and office equipment; and also cables for almost all modern electronic products you can see. We cater to our customer's every need with our design services and quick lead time. Orders of large quantity and small quantity are both always welcomed.
    http://www.darlox.com/
