element14's The Ben Heck Show
Forum How to get started?
  • Subscribers 30 subscribers
  • Views 424 views
  • learn
  • help
  • engineering
How to get started?
Alright so I want to build basically Ben's portable Pi gaming console, only with the tiny keyboard/touchpad combo you see most often used for the Pi instead of a gaming controller. However, I have no engineering/electrical/mechanical skills whatsoever (I've built a computer. That's it.). I've gotten inspired to do stuff like Ben does, but I don't know where to start. I don't want to take a class of any kind, as I don't have time or excess money for that. I would love to teach myself how to do this I just need a push in the right direction. I wonder if Ben would take an intern? Haha just kidding. Any help is greatly appreciated.
-Justin
  • benheck
    benheck over 13 years ago +1 verified
    Check the forums to find the Pi case files. You should also check out the Pocket BASIC computer episode from last summer. It uses a Xbox chatpad keyboard, which, if programmed at the right baud rate, should…
  • benheck
    0 benheck over 13 years ago
    You should also check out the Pocket BASIC computer episode from last summer. It uses a Xbox chatpad keyboard, which, if programmed at the right baud rate, should work with the Pi on the RX TX lines.
    0 e14 Contributor over 13 years ago in reply to benheck
    Cool, thanks Ben!
