element14's The Ben Heck Show
Forum Infrared light switch
  • Subscribers 29 subscribers
  • Views 406 views
Hi, im building a light switch with a infared led, when somebody put the hand between the led and the sensor, the circuit will send a signal to a relay, and then turn on the lights, my problem is, i want the the circuit stays on, even when the hand is removed, and when somebody pass the hand again, the lights turn off. Well, i have to to this without use ant IC`s, just logic gates, transistors and the basic components of eletronics... i was thinking in build a memory circuit with logic gates, but i dont figured out how do it..
obs.: i can use the ic 555.
    you may want to look into a flip flop concept. see this link http://en.wikipedia.org/wiki/Flip-flop_(electronics) where the 555 can also be used but not sure in what exact mode
    Lol, i found th solution, i already knew the flip-flop, but i was trying do something complex, the solution that i found was put a flip-flop JK, with 1 and 1 and the clock is my signal, that comes from my circuit.
